KB86300
Published: January 3, 2017
PAC Display Runtime Pro: Historical SuperTrend graph may show date of 1/1/1601 if data source is a database
Versions affected: R9.0a through R9.5c
Problem is fixed in version: R9.5d
If you overwrite the default database table name in order to log more than one SuperTrend to the same database table (not recommended), then the date displayed along the bottom of the resulting Runtime SuperTrend graph may be invalid. (In testing this issue, the date displayed on the graph was 1/1/1601).
