KB86299
Published: December 13, 2016
PAC Display Configurator: Alt+A keyboard shortcut doesn't work on Alarming Setup > Options tab
The Alt+A keyboard shortcut in PAC Display's Configure > Alarming Setup > Options tab doesn't toggle the check box for the "All alarms enabled at startup" option.
Click the check box with the mouse.
