KB86288
Published: January 4, 2017
When a relative path is modified, PAC Display incorrectly adds "../" to the file path
Problem was discovered in version: R9.5c
May affect lower versions
Problem is fixed in version: R9.6a
Note: This issue affects historical data logs, SuperTrend historical logs, and Alarm logging.
If you modify the relative path of a historical log file (Configure Historical Data Log > Modify > Log to File ), PAC Display incorrectly adds the characters ../ to the file path. This issue causes the log to be written to original   folder, instead of using the relative path.
