KB86285
Published: December 14, 2016
PAC Display SuperTrend "Make Path Relative to Project" check box does not retain its setting
Problem affects versions: R9.5c
Problem is fixed in version: R9.5d
In a SuperTrend in PAC Display Configurator, you can check "Make Path Relative to Project" when you set up the historical log file. But after you click OK and then return, this box does not remain checked.
