KB86284
Published: December 14, 2016
PAC Display Configurator may crash when opening a project with initial window states configured
Problem was discovered in version: R9.5c
Problem is fixed in version: R9.5d
If you've configured initial window states in a PAC Display project (Configure > Runtime > General Tab > Define Default), after you save and close the project, PAC Display Configurator may crash when you try to re-open the project. This issue may also cause the project file to become corrupted.
You typically configure initial windows states when a project has multiple windows. You can avoid this issue by configuring an initial state for no more than one window. (You configure initial window states in the Pop Window dialog box.)
