KB86248
Published: October 3, 2016
Cancelling or attempting to turn off passcode causes groov View for mobile to crash
Problem affects versions: R2.42 and lower
Problem is fixed in version: R2.43
In groov View for iOS, when you try to cancel the input for passcodes, the app will crash. The app also crashes if you try to disable the passcode option by entering the code to disable it.
This issue occurs only on an iPad. iPhone and iPod are not affected.
