KB86246
Published: September 28, 2016
In groov View mobile app, automatic login does not work if username or password includes "&"
Problem affects versions: All versions before R2.43
Problem is fixed in version: R2.43
In the groov View mobile app, automatic login does not work if the username or password contains an ampersand (&). The login page appears.
Either log in manually or change the username or password so it does not contain "&".
