KB86225
Published: September 27, 2016
Pressing a key with no project open may crash PAC Display Configurator
Versions affected: All versions through R9.5b
Problem is fixed in version: R9.5c
After you’ve closed a project, PAC Display Configurator may crash if you press any key on your computer’s keyboard. Note that this issue doesn’t happen if Configurator opens without loading a project—It happens only when you press a key after a project has been closed.
