KB86223
Published: September 27, 2016
PAC Control: Shared subroutines can give incorrect results
PAC Control Basic
PAC Control Professional
Versions affected: R9.5a and R9.5b
Problem is fixed in version: R9.5c
If you change a subroutine that is shared with other strategies, you’ll immediately see the results of the change in the strategy you’re working on, but the other strategies won’t reflect the change until after you’ve compiled them.
When a subroutine has changed, be sure to compile every strategy that uses it.
