KB86221
Published: September 22, 2016
groov Trend gadgets allow negative periods
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.2a
Problem is fixed in version: R3.3a
In groov Build, the Trend gadget allows you to set a negative period. If you do so, no data will be rendered and no data stored.
