KB86214
Published: September 28, 2016
groov View mobile app fails to connect to sites with an IPv6 address configured to use a name
Problem affects versions: R2.42 and lower
Problem is fixed in version: R2.43
The groov View mobile app fails to connect to sites that have an IPv6 address when the connection is configured to use a name rather than a hard-coded IP address. For example:
  • https://mygroov.mydomain.com does not work
  • https://159.200.50.43 does work
When configuring the link, use the equivalent IPv4 address if available.
