KB86204
Published: September 28, 2016
groov View for iOS does not correctly support usernames and passwords that contain spaces
Problem affects versions: R2.42 and lower
Problem is fixed in version: R2.43
In groov View for iOS, if you use a username or password that contains spaces, you cannot get into the app. When you try to connect, you are not logged in and are returned to the login page.
Use usernames and passwords that do not contain spaces.
