KB86170
Published: September 14, 2016
PAC Manager Configuration file doesn't retain Fahrenheit setting for E2 brains
PAC Manager
Version affected: R9.5a
Note: This issue affects only E2 brains configured by using a PAC Manager configuration file (sometimes called an .OTG file).
If you use a PAC Manager configuration file to configure or change an E2 brain's Temperature option to Fahrenheit, the option will change to Celsius after you save and close the configuration file.
Create a Memory Map Value for the E2 with the following values:
  • Address: F0380008
  • Value: 1 for F, 0 for C
  • Type: 4-byte Int
