KB86159
Published: September 16, 2016
PAC Display Runtime terminates if the project's ODBC data source is not available
PACDISPLAYPRO
Versions affected: R9.4a through R9.5b
Problem is fixed in version: R9.5c
Note: This issue affects only PAC Display Professional.
If a project's configured ODBC data source is not available when PAC Display Runtime starts, Runtime displays a message that it must terminate.
Instead, Runtime should keep running, write an error message about the ODBC data source, and continue trying to connect to the data source.
