KB86158
Published: September 27, 2016
PAC Display Professional may not save configuration for logging SuperTrend data to a file or database
Versions affected: R9.5a and R9.5b
Problem is fixed in version: R9.5c
If you configure PAC Display Professional to log SuperTrend data, PAC Display may not keep your settings when you close the SuperTrend Setup dialog box.
For example, if you configure PAC Display to log SuperTrend data to a database, and then click OK to close the SuperTrend Setup dialog box, the next time you open the dialog box, you may discover that the configuration has switched to the settings that log to a file.
