KB86148
Published: September 20, 2016
Loss of floating point precision in OptoOPCServer and PAC Display
OptoOPCServer
Problem is fixed in version: OptoOPCServer R9.5b and PAC Display R9.5c
Note: Float tables are not affected by this issue.
When OptoOPCServer or PAC Display writes a floating point value such as a float variable, an up or down timer, a TPO parameter, or a PID parameter (such as the gain coefficient, integral coefficient, derivative coefficient, or the scan time), the value is sometimes rounded to a single degree of precision. For example, the number 3.14158 may be rounded to 3.1.
