KB86136
Published: August 30, 2016
PAC Display: Existing graphics don’t recognize configured digital input points and new graphics can't be configured for digital input points
R9.5a and Beta versions B9.5b builds 0001 through 0013
R9.5b
Graphics that were configured for digital input points in PAC Display R9.4c or lower will not write data when running in the affected versions of PAC Display Runtime. For example, if you used PAC Display 9.4c to configure a SuperTrend pen for a digital input point, and then upgraded to PAC Display 9.5a, the pen won’t write log data for the point.
Also in the affected versions, you can’t configure digital input points for new graphics (such as alarm points and SuperTrend pens) because Tag Selection dialog boxes don’t display "Digital Input Point" in the Item Type pane.
