KB86133
Published: August 16, 2016
OptoDataLink doesn't write empty string values from database tables to strategy tables
OptoDataLink
Version affected: R9.5a
When writing string values from a database table to a PAC Control string table, if OptoDataLinkRuntime encounters an empty value, it writes an error message ("Object cannot be stored in an array of this type") to the Error Log. Instead, it should write the empty value to the strategy table.
