KB86123
Published: August 26, 2016
PAC Display Runtime generates blank entries (separated by commas) in triggered historical logs
Versions affected: R9.5a and Beta versions B9.5b build 0001 through 0011
If you've configured more than one tag value to be written to a triggered historical data log*, each scan will write a line containing the tag values, followed by multiple blank entries (lines of commas).
Note that the number of lines with blank entries equals the number of configured tags minus 1.
* A triggered historical data log is a log that PAC Display Runtime starts writing to, only after a configured Start Trigger tag has reached a configured value.
