KB86116
Published: August 23, 2016
PAC Display Runtime: Discrete alarms trigger only when the tag's value is -1
Version affected: R9.5a
Normally, when a discrete alarm is configured as "True/On," Runtime displays an alarm whenever an integer (or integer table element) tag's value is anything other than " 0 " (zero).  However, in the affected version, discrete alarms are triggered only when the tag's value is "  -1  ".
To work around this issue, modify your PAC Control strategy to use a value of  -1 in the tag being used to trigger the alarm.
