KB86108
Published: August 19, 2016
PAC Display text objects with multiple styles revert to Normal style (and font may change) when project is reopened
Version affected: R9.5a
If you apply more than one style to a text object in PAC Display Configurator (for example, making the text both bold and underlined), the style reverts to Normal after you close and reopen the project. In addition, combining styles may also cause the object's font to change.
Note that applying a single style (for example, only Bold) works correctly.
