KB86103
Published: August 23, 2016
PAC Display Runtime: Unable to close "Waiting for async operations to complete" message
Version affected: R9.5a
Runtime sometimes fails to close the "Waiting for async operations to complete" message when you attempt to close the active window. For example, this can occur after:
  • Selecting an option in a combo box.
  • Clicking an object that prompts you to send a string, but instead, you click Cancel.
When this issue occurs, the only way to close the message is to exit Runtime.
You can prevent this issue in Runtime by not clicking Cancel when attempting to send a string, and by avoiding the use of combos boxes.
