KB86092
Published: September 28, 2016
Opto aPAC displays timer variables as integers rather than floats
Problem affects versions: R1.40 and lower
Problem is fixed in version: R1.50
When you view a timer variable in the Opto aPAC mobile app, the data is displayed as integer data types rather than floats, and the values are incorrect. The issue applies to both up timers and down timers.
