KB86083
Published: September 26, 2016
Opto aPAC randomly shows "Invalid Length Returned" when viewing string tables
Problem affects versions: R1.40
Problem is fixed in version: R1.50
When you're viewing a string table in the Opto aPAC mobile app, you may see an "Invalid Length Returned" message, even though the length is OK. If you tap on the string table element that shows the message, you see the correct string in the string variable dialog. Then when you go back, the list is correctly populated.
