KB86002
Published: September 26, 2016
Opto aPAC app crashes, often after "Connect Failed!" message, while communicating with I/O points
Problem affects versions: R1.40
Problem is fixed in version: R1.50
The Opto aPAC mobile app crashes with the message: "Unfortunately, Opto aPAC has stopped." This may be preceded by a message near the bottom of the aPAC screen that says: "Connect Failed!"
