KB85952
Published: June 30, 2016
Optomux responses on E1/E2 may be delayed
E1
E2
Problem affects versions: All versions
Problem is fixed in version: Firmware R1.2b
On an E1 or E2 brain board, Optomux responses containing more than 64 ASCII characters may be delayed by 100+ milliseconds. Commands that return return four ASCII characters of data per module and request all module positions are likely to trigger this issue. Command examples:
  • On an E1: Read Counters, Command W
  • On an E2: Read Analog Inputs, Command L
    Send commands that cause responses of 64 ASCII characters or fewer. For the commands indicated in Symptoms, read up to 8 modules at a time.
