KB85947
Published: July 28, 2016
groov 3.2 update fails on groov Box with groov Admin version lower than 43
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: groov Admin R1.570.42 and lower
If you try to install groov 3.2 or higher on a groov Box that has a groov Admin version lower than 43, the installation will fail with an error that says the update file was not valid.
Due to a required internal change to the groov Box, you must install groov Admin version 43 or higher before installing groov 3.2 or higher.
