KB85877
Published: May 26, 2016
Some E1/E2 configuration values not properly stored to flash memory
E1
E2
Problem affects versions: Firmware R1.2a
Problem is fixed in version: Firmware R1.2b
When you configure an E1 or E2 brain board and store the configuration to flash memory, some items are not properly stored and will be reset to defaults when the brain board is reset.
Configuration items affected are:
  • Modbus float format
  • IP filter address/mask 8 and 9
  • Stop incoming broadcast values
OptoMMP memory map addresses affected are 0xF03A0060-0xF03A0073, and 0xF0390000-0xF0390003
