KB85841
Published: July 28, 2016
groov Indicator Buttons don't fully display animated gifs
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.1a and higher
Problem is fixed in version: R3.2a
If you use an animated gif as an Indicator Button's image, you'll only see the first second or so of the animation on Chrome, Safari, and groov mobile apps. The animation resets to the beginning for every tag update.
This issue does not affect Firefox or Internet Explorer.
Use Firefox or Internet Explorer.
