KB85806
Published: May 26, 2016
In groov, OPC UA Static Array may generate index error asking for a negative index value
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a and higher
Problem is fixed in version: R3.2a
In groov Build, when you try to index an OPC UA static array, an error appears requiring a negative integer for the index.
