KB85796
Published: April 29, 2016
In groov Build, OPC UA Static Array tags are disabled in the Tags tree
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects version: R3.1a
Problem is fixed in version: R3.1b
In groov Build, all OPC-UA array tags except for Byte Arrays are disabled in the Tags tree, so you cannot choose them.
