KB85758
Published: April 22, 2016
PAC Display Runtime - Incorrect vertical position behavior when objects grouped
Problem was discovered in version: R9.4g; may affect previous versions
In PAC Display Runtime, grouped graphics return to their default position despite tag value and dynamic attribute settings.
After you close and reopen the window, grouped graphics with dynamic attributes set to move vertically and send a discrete value will return to their default position.
In PAC Display Configurator, ungroup the graphics and assign them the same dynamic attributes individually.
