KB85696
Published: March 30, 2016
E1/E2 firmware upgrade takes too long
E1
E2
Versions affected: E1/E2 Firmware R1.1f and lower
Problem is fixed in version: E1/E2 Firmware R1.2a
It make take over 15 minutes to upgrade the firmware on an E1 or E2 brain that currently has firmware R1.1f or lower.
IMPORTANT: DO NOT CYCLE POWER during the upgrade.
Cycling power during the upgrade may damage the brain.
The upgrade is complete only after the STAT LED stops blinking and is solid for more than 5 seconds.
