KB85604
Published: April 7, 2016
PAC Display Runtime - Recipe upload may time out and report an error in the recipe format file
Problem affects versions: B9.4h dated 11-4-2015 through 2-23-2016
When a recipe upload is triggered, it may time out after several seconds, even though the recipe file is valid. In the Event Log you see a message that there is an error in the last line of the recipe format file.
This issue occurs only if a download recipe has the same trigger tag as the upload recipe.
Use a different tag to trigger the uploading and downloading of the same recipe.
