KB85591
Published: May 26, 2016
PAC Display Trends and SuperTrends do not use correct controller's data after Window > Switch Control Engine
Problem affects versions: All versions
In PAC Display Runtime, Trends and SuperTrends do not show data for a controller you select using Window > Switch Control Engines. Also, the name of the new controller does not appear on the window's title bar.
Other graphics correctly display the data from the new controller, but Trends and SuperTrends continue to display data from the old controller.
