KB85550
Published: March 28, 2016
In groov Admin, cannot get PEM/CSR file after uploading CA-signed certificate
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects version groov Admin R1.570.43
After you have uploaded a CA-signed certificate file, the links to download the PEM format or CSR don't work.
