KB85511
Published: April 7, 2016
PAC Display Configurator - Importing alarm points may result in several "String Resource Not Found" messages
Problem affects versions: R9.0a and higher
If you have exported alarm points and then import them, you may receive several "No String Resource found for <number>" error messages. The <number> is usually 5918 or higher.
