KB85510
Published: April 7, 2016
PAC Display Configurator - "Control engine not found" error after importing alarm points
Problem affects versions: R9.0a and higher
You can re-configure control engines in PAC Display Configurator using Configure > Control Engines. If you change control engines and then export alarm points to a text file (comma-delimited), the old control engine names are exported rather than the new ones. Importing these alarm points results in an error message: "Control Engine not found"
After you change the control engine names, save the project, and then close and re-open it.
