KB85457
Published: January 19, 2016
SNAP-PAC-EB2-W brain continuously resets after wireless configuration is stored to flash
SNAP-PAC-EB2-W
Problem affects: Firmware R9.4c and higher
When you configure the Wireless LAN on a SNAP-PAC-EB2 brain in PAC Manager and click Apply, the brain continuously resets until you restore it to defaults using the Reset button on the brain.
This issue affects only the SNAP-PAC-EB2-W. It does not affect the EB1-W nor the Wired+Wireless SNAP PAC R-series controllers.
