KB85398
Published: January 7, 2016
PAC Display Configurator may crash when you configure table controls in projects that were last saved in pre-R9.0a versions
PAC Control Basic Configurator
PAC Control Professional Configurator
Problem affects versions: R9.0a through
B9.4h (beta version)
dated 12-22-2015 and earlier
If you attempt to configure a Table Control object that was last saved in a pre-R9.0a PAC Display project, PAC Display Configurator will crash when you click OK to close the Configure Table dialog box.
(See the Versions section for the PAC Display versions affected by this issue.)
