KB85379
Published: January 7, 2016
PAC Display Configurator might not load all strategy tags when the strategy includes SNAP-PAC-R1-B I/O Units
Problem affects versions: All versions
PAC Display Configurator stops loading strategy tags as soon as it encounters a SNAP-PAC-R1-B I/O Unit in the strategy.
It then displays an "Unable to load Board Objects" error message.
This issue can prevent tags in the strategy from being assigned to Dynamic Attributes.
Use PAC Control to change the configuration of SNAP-PAC-R1-B I/O Units to SNAP-PAC-R1, and then save the strategy.
Next, close and re-open the project in PAC Display Configurator so that it reads the updated PAC Control strategy.
Note: B-series mounting racks support 4-channel digital modules only in positions 0 - 7. (Analog and serial modules can be in any position on the rack.)
