KB85373
Published: April 7, 2017
SoftPAC: Unable to open UDP communication handle (-437 error)
SOFTPAC
Versions affected: All versions of PAC firmware through R9.5d
Problem is fixed in version: FW R9.5e
When you try to open a UDP communication handle, PAC Control returns a -437 ("No acceptable socket interface found") message.
This happens only when the strategy has already opened and closed a UDP communication handle multiple times (more than 500 times), or when the strategy is configured with a very large number of UDP communication handles.
Keep UDP communication handles open (to avoid opening and closing too many times), or use a hardware controller.
