KB85340
Published: January 19, 2016
In the .NET controller SDK, a communication fault is returned for a floating point value or analog point state
.NET Controller Software Development Kit for SNAP PAC
Problem affects versions: R1.0.2.0 and lower
Problem is fixed in version: R1.0.3.0
A communication fault is returned from most data access methods and when writing a floating point value or analog point state to the PAC controller.
Cultures use different characters to separate floating-point number representations. The PAC controller assumes all floating point separators are periods, for example 3.14159, as used in the United States. Other cultures separate the number with a comma, for example 3,14159.
