KB85277
Published: November 30, 2015
PAC Manager times out almost immediately when attempting to install firmware
PAC Manager
Versions affected: 8.0a and higher
PAC Manager cannot install firmware on any Opto 22 Ethernet-based brain or controller operating behind a router that does not have port forwarding enabled for UDP. Instead, PAC Manager displays a timeout message almost immediately.
To install firmware in a brain or controller, you can connect to the device directly (for example, through a switch), or temporarily change your router's settings to allow UDP communication.
