KB85261
Published: November 16, 2015
PAC Display Configurator crashes when you load a project with an unnamed alarm point
Versions affected: R9.4A through B9.4H (prior to Oct. 27, 2015)
When you create an alarm point in PAC Display Configurator, you aren't required to give the alarm point a name. However, if you don't name the alarm point and you save the project, PAC Display crashes when you attempt to re-open the project.
