KB85083
Published: December 10, 2015
Cannot create file on microSD card (error code -417)
Problem affects versions: Firmware R9.4a and higher
When creating a new file on the microSD card (either using the Open Outgoing Communication command in PAC Control or writing from a host, like an FTP client), you may intermittently receive a -417 error code. Eventually, it will occur every time.
This issue is most likely to occur when the file names are very similar and you are creating lots of files.
To recover, restart the controller either by using the PAC Manager Status Write page or by cycling power to the controller.
