KB85061
Published: September 28, 2015
In PAC Manager, SNAP-AICTD module scaling values are configured incorrectly
PAC Manager
Problem affects versions: 9.4b and higher
When you use PAC Manager to configure SNAP-AICTD analog input modules, the values returned from the input modules are incorrect. This issue was the result of a change in 9.4b.
The lower scaling value in the tagGAins.def file can be changed to -273.0 and then the configuration re-downloaded.
Opto 22 has resolved the issue.
