KB85060
Published: September 24, 2015
In EtherNet/IP Configurator, SNAP-AICTD module scaling values are configured incorrectly
EtherNet/IP Configuration Software
Problem affects versions: R3.0l and higher
Problem is fixed in version: R3.0n
When you use the EtherNet/IP Configurator to configure SNAP-AICTD analog input modules, the values being returned from the input modules are incorrect. This issue was the result of a change in R3.0l.
The lower scaling value in the EIPAins.def file can be changed to -273.0 and then the configuration re-downloaded.
