KB85045
Published: December 9, 2015
Can't properly resize EtherNet/IP Configurator dialog boxes in Windows 10
EtherNet/IP Configuration Software
Versions affected: All versions through 3.0p
R3.0n
If you're using Windows 10 and you try to resize a dialog box in EtherNet/IP Configurator, you can make the dialog box larger, but you can't make it smaller.
