KB85044
Published: November 30, 2015
Can't properly resize PAC Manager dialog boxes in Windows 10
PAC Manager
If you're using Windows 10 and you try to resize a dialog box in PAC Manager, you can make the dialog box larger, but you can't make it smaller.
Opto 22 has resolved the issue.
